[2024] Snow Blower Settings Recommendations
Overlap (inches) Settings
  1. For thicker snow or if there are missed spots, choose 11.88 inches.
  2. To improve clearing efficiency, choose 0 inches (though this may result in some missed snow).
  3. A balanced option would be 5.88 inches (recommended).
Auger Speed Mode
  1. Recommended settings: Quiet or Mild. Both light and heavy snow can be cleared with no speed restrictions.
  2. Robust and Turbo modes are generally used for clearing wet snow, but they have speed limitations, only usable on Slow or Medium speed.
Auger Minimum Height (inches)
  1. For flat surfaces (e.g., concrete, asphalt), set the height to 0 inches.
  2. For brick surfaces, cracks, or uneven roads, set the height between 0.4 to 0.6 inches.
  3. For gravel or muddy surfaces, set the height between 0.8 to 1.2 inches.
  4. For non-snow activities, set the height to High.
Deflector Angle
  1. To avoid throwing snow onto neighbors’ property, choose an angle between -5 to 5 for both the lowest and highest positions.
  2. If you find the snow throw distance to be too short, choose an angle between 40 to 50 for both positions.
  3. To automatically adjust the snow throw distance based on the machine’s position, select an angle between -5 to 50 for both the lowest and highest positions. (The farther the machine is from the snow throw area, the farther the snow will be thrown, and vice versa).
