Auger speed and height setting per run vs per area
In my first couple weeks of regular use blowing snow, I’ve found that I generally need to set the auger speed and height setting depending on the conditions of the day (how packed the base layer is, and how deep and/or wet the new snow is). That requires going through every area and sidewalk and updating all the numbers. Can you add a feature to override the area settings with a parameter when starting the plan, or in the work settings?
I agree 100%. It is currently pretty cumbersome modifying all the settings based on the weather conditions and the state of the driveway.
Would be nice if those commonly adjusted settings could be surfaced in a better way for quick adjustment.
I agree. I keep adjusting the setting depending on the conditions. I also wonder if I could change the setting from parallel to circular blow on the driveway to see which one is faster, but could not do that change.
