[2024] Why is the Data Center Flashing Red?
  1. Check for damage to the RTK Antenna on the Data Center
    If the RTK antenna is damaged, it can cause the Data Center to flash a red light
  2. Verify if the Data center has been upgraded to the latest version
    If you have upgraded the Data Center, it is necessary to reinstall the Data Center.
    If you haven’t upgraded it yet, Please first update the Data Center to the latest version,
    and then reinstall the Data Center.
The red flashing light on the Data Center is a new light signal introduced after our firmware update.
It indicates that there is a significant deviation in the latitude and longitude during detection.
This issue usually occurs when the machine has just been received, or when the Data Center has been moved a long distance and powered on again.
This is a self-correction mechanism. If you encounter this situation, ensure that the Data Center is upgraded to the latest version and then reinstall the Data Center.
