New install, Data center flashing red
I’m trying to get my Yarbo set up but the Data Center is flashing red and the Yarbo itself won’t find GPS. I’ve read the tech articles as well as the new user FAQ but nothing seems to help, and I’m a little confused about some of the wording in the FAQ.
First, the details:
The DC is connected to my POE switch via ethernet. The switch sees the DC and it has an IP address. It is connected at 100mb/sec. I have tried power-cycling the DC and waiting 24+ hours, as it was pretty overcast and rainy when I first set it up.
I installed the Yarbo to my app before connecting to the data center. The FAQ says that if the DC is added to the app, to remove it first… Except I don’t see how to add it to the app. Each time I try to connect, it takes 30+ seconds and I have to be within bluetooth distance from the DC. There’s no “install” or “add to app” or anything like that.
The DC shows as having a lower firmware version than what’s current, but when I click the download button it tells me it’s at the latest version.
I’ve tried driving the core around my yard to see if it would pick up a GPS signal but so far it cannot - I assume that that’s because the DC isn’t working yet?
Some pictures of what it looks like in my app:
It sounds like your DC isn’t initialized. You can verify this by going into settings, diagnose tools and seeing if you have a “FALSE” under RTK mode. Go into the app and click on “Reinstall Data Center”. It’s under settings and towards the bottom.
Thanks for sharing all the details — that’s really helpful. I’ve checked the data on our end, and based on what I see (and as Bryan mentioned), it looks like the Data Center may not have initialized successfully.
Could you please try reinstalling the Data Center to see if that helps resolve the issue?
Please keep us posted on how it goes — we’ll be here to assist further if the problem persists!
Thanks @bryan.wheeler - That’s what I needed to do! After finding and clicking the reinstall data center, it found the DC and then showed me the signal strength (something it has never done before) and then everything was green! My Yarbo now shows a GPS symbol so I think I’m ready to go!
Awesome, glad that worked out!
I am having the same issue. However reinstalling the DC is not working for me.
Make sure the DC firmware is up to date. Unplug power to it and the core for 5 mins. Power up the DC, then the core. When you hear ready to work, try reinstall DC again.
Thanks for sharing this. Could you please try Bryan’s suggestion first and see if it helps?
If the issue still persists, feel free to submit a support ticket, and our team will take a closer look and investigate further.
Appreciate your patience, and please keep us updated!
