Can’t wait to finally put Yarbo to stress test the snow storm over this weekend. A few thoughts to share
Does it make sense to heat the antenna so that its RTK performance won’t be impacted by the deep snow?
Can we implement a continuous mode over a period of time. This means a) Yarbo blows the snow for a given area, b) once it’s done, go back to charge, c) once it’s fully charged, blow the same area, d) repeat until the set finish time.
Heated antennas could cause two problems, icicles and the wire could impede the signal. Generally, it’s fine, even if covered by some snow. If it gets too tall, it could impede the signal, but it’s best to clear off Yarbo anyways if it gets this way.
Hi there, thanks for sharing your questions and thoughts!
Regarding the antenna, we currently do not plan to add heating. As Bryan mentioned, the antenna generally works fine even with some snow coverage, and heating could introduce other issues. If snow buildup becomes excessive, it’s best to clear it off manually.
At the moment, we don’t support a continuous mode that repeats automatically over a set time period. However, you can use the Work Twice feature to have Yarbo clean the same area twice in one session, which can be helpful during heavy or prolonged snowfall: Work Twice & Second Work Settings | Yarbo Wiki
Thanks again for the thoughtful feedback—we really appreciate it!
