About the Mapping Issues category
Discuss any issues related to mapping.
Please add a option to edit / move existing no go areas.
For example, when I define one no go area and let yarbo mow at the end, you can recognize if the no-go area was not exactly (because of bad GPS). When this happens, I have no chance to move the no-go area, so I have to delete it and define a new one again… Would be much easier when moving would be allowed
While I’m sure many owners want perfect lines everywhere, I am not one of those people, I would much prefer Efficiency! I have a Map, that I’m going to redo, because it drives me crazy. What’s wrong? The map will have the Yarbo go to the furthest point and then it will be going through another area that should be done immediately but instead it goes all the way to the opposite corner of the yard which is 400 feet away, do that area, then go all the way back to the area by the furthest spot. The Mapping is so inefficient it drives me insane! I would like to be able to # the paths and even eliminate paths prior to starting the mowing so it doesn’t waste so much time!
