Request for Must-Go Zones
I’m sure many of you have the situation where Yarbo misses 2 inches of grass in one spot around the perimeter of an Area, and you can’t tell it to mow behind the perimeter in the settings because it’s super tight in other spots.
What if Yarbo offered us a “Must-Go” zone so we can ADD spots to our Areas without having to re-map everything?
Thank you for your suggestion! Would the “edit map” feature work for your needs? You can slightly expand the area in the spot where the grass is missed without having to remap everything. Please let me know if I’ve misunderstood anything!
You might be able to do that with a Dead-End. Maybe.
But be very careful the first few times you try it.
Great suggestions! I thought Edit Map only had the Split Area feature. I didn’t see the Expand Area option before now. I’ll give it a try very soon.
