Add optional orange/caution light lift/extension/pole
While the blower has white lights in front - the orange caution light is not visible over the blower module, as well as the snow thrower. It would be great to have either the same type of light added to each module, or to allow the existing light to lift up above the modules (preferably on something flexible to avoid breaking such as people report of the antennas).
I can envision a semi-rigid mount that puts the light on a flexible tube - can be low against the body or articulated up when using a higher module - but would give way if the unit were to go under an ungiving obstacle.
Image just a brief example, I’d prefer something that can lay flat on top but still be seen when only acting as Core, but can lift up when using other modules.
Hi @PeterInWa Thank you for sharing! While we don’t have plans for this in the near term, we really appreciate the suggestion and will pass it along to the team for future consideration.
This would also be useful to bring an attention getting light to car/eye level, or at least higher up - to avoid car/truck collisions.
