After market Data Center GPS antenna
I recently have been fooling around with Pen testing my network for intrusions. On the device I was using I switched from the internal GPS antenna which got close to 20 GPS satellites in the house. I added an external antenna and received over 50 satellites. The antenna I switched to on my pen testing device was a “RTK GNSS Active Antenna High Precision Helix Positioning GPS GLONASS Beidou BDS Galileo Four-Star Multi-Frequency Antenna, Slinkdsco” from Amazon. The antenna has a male post.
Would this be a good alternative?
The Pro RTK antennas Yarbo offers are better IMO.
We’re not sure how this third-party antenna would perform with the Data Center. But as Bryan mentioned, Yarbo’s RTK Antenna Pro could also be a good option to consider, since it is designed specifically for Yarbo’s RTK setup. RTK Antenna Pro for Data Center & Rover – Yarbo
I have the new antennas (that attach to the rover). They work very nicely. I’m talking about the GPS antenna on the Data Center itself.
You can use the same Pro antenna for the DC.
They work great on the DC just be aware that the brace to the HaLow antenna will no longer fit.
Unless you are lucky and have the old version.
There’s a 3d print file for that.
https://makerworld.com/en/models/3258812-yarbo-datacenter-rtk-pro-antenna-brace?from=search#profileId-3694057
You can also use the same RTK Antenna Pro on the Data Center.
That is the tall antenna?
The middle antenna on DC.
