We have a way to start into a plan using % but we need a way to set the starting point when a plan is run from the beginning. It seems logic at time selects starting points far into area when optimally it should start at a better location.
Actually this has got a lot better recently, but the problem is now, the rover drives into the area, then does a 180, then hunts around back a forth, and then takes a hard 90 degree turn, all beating up the yard in the same area almost every time. It really makes no sense how it makes these odd movements.
yes, seen this often as i watch my lawn suffer.
Mine pulls off the dock, exits the pathway and then goes to a start point right beside the pathway at the edge. I’m like just pull to the edge of that pathway (damage is already done there anyways) and start and then turn out of the pathway to the lawn edge and continue on. No dance necessary.
That being said, being able to select a starting point and also being able to specify that it is randomized would be ideal. Right now it choses the same start point near my dock and that area is just getting annihilated on both of my cores.
In two of my area’s I have to keep moving the pathway so it is not doing the same turns in the same spots over and over again.
Am I the only one that Yarbo chooses a starting location across the lawn such that it ALWAYS drives an ugly diagonal line across the grass both at the start and a slightly different ugly diagonal line when it is complete?!
DRIVES ME CRAZY that it can’t navigate to the closest boundary when starting/ending. My Yarbo taunts me by selecting a starting/ending location that causes it to drive diagnoallly across the middle of my lawn. Is it so hard to program Yarbo to navigate to a boundary FOLLOWING THE LINES IT MOWED and driving to the pathway in the boundary?! Seriously we have beautiful sculpted lawns with ugly diagonal lines criss crossing.
[stepping off my soapbox]
Been a long begged for feature to not do this. However, there are definitely other issues I’d like fixed first. The return line I don’t really ever really see.
Ending is always a cross country trip across the yard, so is recharging in the middle of the plan.
Yup. Pathway Offsets were a great improvement. Like everything else, they leave something half-finished.
Thank you all for sharing your suggestions! I understand that several of these requests have been raised multiple times. I’ll bring them up again with our product team for further consideration.
@Yarbo-Forum the Transit Lines distract from an otherwise beautiful result from Yarbo. My neighbors mention it in a quasi-degrading way for the Yarbo, “Beautiful lawn. What are the crisscross lines? Does the Yarbo get confused? Is it reliable?” As @B-Mod mentioned there are even more transit lines when an Area requires recharging.
@bryan.wheeler while I would agree there are regularly more important issues (e.g. security patching, No-Go Zone adherence, etc.), there are few active issues impacting everyone. Most issues thankfully impact a limited subset of users. What I don’t understand is why after YEARS it is not addressed? They certainly use the manicured-look in their advertisements.
Lastly, I know many Owners don’t care about the appearance of the lines. They mow for Functional purposes. There are many Owners who want both Functional mowing and the Consmentic of a manicured lawn.
[stepping off my soapbox until once again I can’t help myself from complaining about this item. They say knowing you have a problem is the first step to recovery. I guess I have taken my first step.
It’s more than a starting point. It is a starting point and entry path. Maybe we can set an entry path with the path offset, similar to the other paths.
Many times I position it near a good starting point. All it has to do is just drive forward and turn on the blades. Maybe at most a little gentle turn. << That’s where things get stupid. Instead of a gentle turn to an obvious starting area, it does a 20 point asterisk turn from hell like it just went stupid.
I suspect it’s mostly too many conflicting priorities combined with the fact that if you did something like follow the perimeter path, it would increase the wear even more in that spot. Which is also another constant complaint from users where it follows the same pathways. I don’t think this is an easy problem to solve. Especially given their path planning is a moment in time for it and it gets the men in black neutralizer when the plan completes. So to do something complex like follow one of the many path lines back that it just cut, it would need a full history to plan that recharge path back with. I have a few other robot mowers and they don’t even have this as an option, it just cuts across the yard too, randomly. Those that claim to support it, I’ve seen complaints it doesn’t always work. So for the industry, I suspect this is a hard problem. Not sure exactly why.
@GROWF @PropellerHead Thanks for sharing your feedback! I’ve passed it along to our team.
