Any way to control the impeller using the physical controller?
Thanks for sharing your experience. As suggested by rgloverii, using the app controller instead of the physical controller may help reduce the delay you’re seeing. You might want to give that a try next time you need to operate Yarbo in manual mode and see if it improves responsiveness.
Great info. Good to know. Thanks
FYI, Today I ran Yarbo completely remotely. I started it early morning to clean one driveway and went to work, by the time I arrived at work Yarbo was done one driveway and recharging. Now I’m sending again for the second driveway remotely from work 30 minutes away and it is running.
Thanks
Thanks. Will do
Awesome!! This is exactly what every Yarbo experience should be like!
I’m actually sitting in my office typing this message while Yarbo works on our driveway. Sure beats going out there and doing the work myself! :slight_smile:
Exactly. I’m only monitoring it from my office through the app and security cameras. Soon it will stop and go back to recharge. The technology is here, then we should use it and learn how to deal with it.
