Automatic perimeter loop change.
Can a feature be added to automatically cycle through the number of perimeter loops to reduce turf damage when turning?
This could reduce where from the unit Turing in the same area each time.
This would be nice as well as an option to vary the direction of perimeter travel automatically too.
Thanks for sharing your suggestion! I can definitely understand how automatically varying the number of perimeter loops could help reduce turf wear caused by Yarbo turning in the same spots repeatedly.
This is a thoughtful idea, especially for users with softer lawns or frequent mowing schedules. If more users show interest in this feature, I’ll be happy to help pass the feedback along to our product team for further evaluation.
How about increasing the number of perimeter laps to 18. This will help the see-saw dance of death and WTF* mowing patterns.
Isn’t that just spiral pattern at that point?
if you don’t use the trimmer otherwise it won’t work.
Would only need the first lap to go the correct way for trimming. However if the trimmer is disabled, or there’s no trim edge defined along that boundary, then it could go either direction.
yes it could be an idea.. I like it
@bryan.wheeler well, if it helps prevent crazy behavior like this (north is up). See mowing pattern on the east side. it got stuck for 37 mins driving back and forth near the upper corner driving north to west.
yarbo area 5.docx (3.5 MB)
Have you tried spiral for that area? Parallel would not be good for that, as you’ve seen. I would also disable all offsets, etc. You could also try adaptive, but I think spiral would be better.
I had the same thought just yesterday.
An Adaptive Mow pattern was shared. Using a Spiral and Parallel patterns moves the cluster to the SW corner. Parallel patterns with a 45, 90 and 135 degree shift moves the cluster to each corner.
well that’s not helpful
