It would be very helpful to add the ability for the user to set a charge limit. Even with daily usage the yarbo is still sitting idle on the docking station with the battery at 100% SOC. Long periods of time at very high or very low SOC causes significantly accelerates capacity degradation in NCM Li-ion batteries. This is even worse as it sits outside in the heat all day.
Not charging regularly above 70%-80% would significantly extend battery longevity. Also, in the future it may be useful to switch from NCM chemistry to LiFePo4 which is much more tolerant to the use case for the yarbo.
Thank you for your suggestion! We understand your concern about the battery health, and we do have a battery management system in place to help maintain its longevity. We also appreciate your feedback on the charge limit feature to further extend the battery lifespan, and we will pass this on to the relevant department for consideration.
Regarding the battery chemistry, NCM is chosen for its ability to provide relatively longer range, which is an important factor for the performance of Yarbo. However, we are always open to exploring improvements and will keep your suggestion in mind for the future.
Thanks again for your input!
I love the feature of being able to return to the charger at user specified (default at 20) percent of charge.
The question is what is 100% of charge in Yarbo, what voltage? If 4.200 or above, it’s probably too high to let the battery sit for long periods, or for that matter, even overnight. If it’s less that 4.200, then maybe 100% is more like 90 or 95%…
So just asking for either a user adjustment on 100% charge, or a bit of factory-provided headroom at the top to maintain the battery a much longer lifetime of 80-90%.
Most of my jobs can be done with about 50% of charge, so I don’t need all the watt-hrs the battery can store. Not everyone has that situation, understand but for those of us that do, but please give us longer battery life over longer run time between charges …pretty please.
Tim
Just one more comment on this most excellent product improvement idea…I’ve been told by Yarbo Support that the BMS is similar to modern cell phones and computers, and that it takes good care of the battery, even at 100% charge. I think that is the problem right there…because those devices are usually optimized for long run times, not long battery life. Which is fine maybe, if you are cutting 3,4,5,6 acres, or more, that might be what you need. For a lot of us (I’m at 1.2 acres pasture land) we would rather have the BMS act more like a modern EV, where the user gets to decide on priority, long life or long run time. You could just add the adjust top end (say 70-100%) in the same place you let the user set the low end (defaults to 20%), for this improvement.
Thanks for having a place to spell this out! And for having an awesome product!
Tim
Point of order:
Don’t forget that the BMC needs to balance the cells on occasion, or else hilarity will ensue. These are not 2S cellphone / laptop batteries.
Cheers
If my math is right (feel free to check), the cells are probably getting balanced every charge. Most BMS are set to balance at some cell voltage over nominal. For NCM lithium, they have a nominal VDC of 3.6V per cell. The Yarbo specified nominal battery pack voltage for Yarbo is 36V, so that means this is a 10S or 10 cells in series pack. Both of the chargers (wired and inductive) are specified in the specifications for 42V, which would be 4.2Vpc (if it’s a 10S pack). It would not be good if the cells are not balanced or being balanced at this point. It’s also not great if the cells are being held at 4.2V for long periods of time, like overnight. I would be very happy with an adjustment on the top end like we have on the bottom end, with the default at 20%.
Just a follow up to this discussion, there is a work around that I found. You can monitor the battery charging on the app, and when it hits 80% (or you choose the level), you can just do a Shutdown from the app. You do have to manually turn it on for the next job, but it beats having the battery sit at 4.2+VDC per cell all night, or longer.
After the shutdown, the battery will no longer charge on the pad.
Tim
Li ion batteries are great.
I’ve had some lithium ion batteries for years that still function top notch because I’m very careful not to over charge, under charge or store with too high a voltage. I’ve also had batteries that have failed quick because I rode them hard and put them away wet, figuratively not literally.
It would be nice if I could set a maximum and a minimum soc for the battery. That way I can control whether I need long run times for mowing or trying to protect the battery for longevity. Knowing that both have their benefits and draw backs at different times.
Thanks!!!
Bumping this. This is very important. If the specs of yarbo are correct and we only expect 500 charge cycles before degrading to 70% we really need the option to limit max SOC.
I had opened another feature request before seeing this already active one.
if 500 cycles is the estimated at 100% SOC, 1000 would be the estimated at 81% SOC. This is double the life.
I have 6 acres and considering only 1 of my charges gets 100% I would give that up for battery health. Plus it takes more time to get from 80% to 100% just the last 20% could take 30minutes to an hour when %20-80 only takes a little more than an hour.
Yep agree 100%.
There is no agreement from Yarbo that this is a bug. They evidently don’t have a single lithium battery charging design engineer on staff.
Tim
Hi Tim,
Are you pretty confident that Yarbo will not continue to charge the battery if the unit is shut down? My reason for asking is the opposite of yours in this case. I don’t want to waste any charging time while I do maintenance on my lawnmower module. I was hoping I could do a shut down while it was plugged in, that it would keep charging while I remove the lawnmower module do my maintenance and put it back on.
Thanks,
Jeff
It will keep charging when plugged into the wired charger and shutdown. It will not wirelessly charge when shutdown. It requires power for this to work.
Thanks Bryan
@Yarbo-Forum - Reviving this thread. This is one of the most requested improvements Yarbo can make, and should take priority, as evidenced in this thread.
Way too many of us are manually shutting the unit down, or driving off the dock to reduce the time the unit stays at high charge levels.
Thanks for bringing this up again! I’ve resubmitted this suggestion to our product team for further consideration.
There are so few unique users on the forum here. Are you consolidating of the 10s of forums spread out?
I know we have asked this before what triggers the great ideas we post and make them move forward. What’s the metric so we manipulate the algorithm and get what’s awesome and helps?
Probably spin the bottle, lol.
