Anyone trying night mowing? I’m getting intermittent camera blocked errors, if I check with smart vision everything looks fine🤷♂️
Also getting some weird repetitive back and forth maneuvers for ~10 minutes…
Camera blocked is a bug they are aware of. Nothing to worry about there. The dancing is also another bug they are tracking. Are you using adaptive pattern by chance? Seems to be more prevalent with that pattern.
As Bryan mentioned, the CM005 error is a known bug that we’re planning to fix in a future update.
In addition, if you’ve selected the adaptive pattern and noticed your unit doing back-and-forth movements, this may be related to another issue we’ve already identified. Our team will be investigating this as well.
Thanks for bringing it up, and we appreciate your patience while we work on improvements.
Yes I’ve been switching between spiral and adaptive, whichever gives reasonably efficient mowing, good to know both issues are on the radar:+1:![]()
Spiral works best for parts of my yard. Long skinny areas beside the driveways and the property lines. ALL other patterns just try to wear out the treads and drive motors. Go forward, back up, rinse, repeat for a long time. ![]()
Often times, literally a giant moth coming for the lights, lol.
Don’t go to the light Carol Anne
