Hi there, thanks for submitting a ticket for this issue. This definitely appears to be abnormal behavior, and we’ll continue investigating the root cause further.
20 cm is max setting, but that would mean even more time spent to mow an area.
Some tiny missed spots (where yarbo is turning around) might be addressed with overlap, but in my case it’s somehow completely missed the stripe and this appeared with some of the latest updates.
I see it mainly when it cuts the turns too short and doesn’t reverse when it finally does get back on the path line. It’s also pretty consistent where it does it. The checkerboard helps get it on the next cut since it moves that problem to a different location.
Yeah, I’ve seen it miss the small spots and also sometimes track ever so slowly back onto the path line. Basically not reaching the center of the line until it gets to the other side. It definitely does this more with obstacle avoidance than anything else.
I saw this a lot recently this spring. My experience was that it was because the lawn was so long. The treads would push down the grass on the first pass so they were too flat to cut on the return pass but would get pushed back up by the mower.
They were all gone by the second or third mowing using either path offset or the auto-rotation. I prefer the auto-rotation because it definitely gets rid of those missed spots on subsequent mows and have mine set to 20 degrees, but there are a few areas I would rather have the Yarbo go the same direction each time.
It would be great to have a 6" offset option for this as the 8" would greatly increase the mowing time.
The 8" overlap helps but I still see uncut grass. I followedthe mower and noticed it does not cut well in the center where the 2 blade ends meet when spinning.
Now I’m playing around the setting and it might be that the mow path offset setting could be causing this …
Let’s hope this gets fixed.
I really like adaptive pattern as it looks like it takes less amount of time than other patterns, but without path offset it will wear the lawn, leave some spots at the same places etc.
