Is there a way I can chain together two work plans such that when work plan #1 finishes work plan #2 starts immediately?
(If this has already been addressed, I’m sorry, but I didn’t know for sure what search terms I should use, I might not have thought of the correct terminology to use when searching posts.)
I believe the best approach to this would be to make a plan#3 that contains work areas from plan #1 and from plan #2 then run plan#3.
You could maybe cobble together a couple schedules (schedule plan#2 at the approximate time that plan#1 should finish)
that solution could run into problems if plan#1 takes longer than expected.
What Ken said. Make a new work plan and put all the areas you want done in them in the order you want them completed. There isn’t a way to queue work plans currently.
Is that a future planned feature that you know of? I would like a pause and wait feature too. I’d like to start clearing the driveway and then wait until a certain time to clear a special sidewalk along the side of our parked vehicle at the last moment. For now I have the 1 schedule end at the same time the sidewalk schedule begins. If I catch it I just end the recharge plan on the first one but I want Yarbo to start going back to the dock so he doesn’t get run over at a certain time either way as well, even if it can’t finish for some reason
Recommend submitting a feature request. I think there might already be one for queues, but doesn’t hurt to submit it if you can’t find it.
