Changing the direction of operation
I do not know how to edit the direction of operation, any help??
What do you mean by “changing the direction of an operation”?
If you mean the pattern Yarbo follows to complete the work area, it’s called “Route Pattern” in the area settings.
If you mean something else, please elaborate.
And if referring to the perimeter direction, that isn’t currently able to be changed.
Could you please clarify what you mean by changing the direction of operation?
Do you mean that you’d like to change the route or path the snowblower follows? If so, that part can’t be adjusted directly. The route is automatically calculated based on two things you select:
The snow-throwing direction, and
The route pattern, which you can edit on the Area Settings page.
By adjusting those settings, the system will recalculate the operating route for you. If that’s not what you meant, feel free to share a bit more detail and I’ll be happy to help :+1:
If you need to change the route pattern you need to change the snow blowing direction then it will change the direction of operation.
