Communication errors after latest Data Center firmware update?
Has anyone experienced intermittent yellow text communication errors across multiple Yarbo units simultaneously following the latest Data Center firmware update?
I’ve seen this periodically in the past with more than one DC on the same subnet/network as each other. Best to put each DC in it’s own subnet/VLAN/network.
IE DC 1 is 192.168.1.0/24 and DC 2 is 192.168.2.0/24
Hi there, as Bryan mentioned, having multiple Data Centers on the same subnet/network could potentially cause communication issues in some cases.
You can try following his suggestion by placing each Data Center on a separate subnet/VLAN/network to see if it helps resolve the issue.
Please feel free to keep us updated on the results.
Another option is to put them all on NetRTK positioning. Don’t forget to place them on their dock, get them charging, save your maps, switch to NetRTK, restore maps from cloud if need be, then correct for map drift.
