Controller access during work plan
There are multiple instances when my yarbo loses gps signal and stops in the middle of a work plan and tells me to move it. I understand this is being worked on which is great. I’ve waited up to an hour at times and it didn’t recover and I need to manually move it.
I can connect the physical controller and move it and it recovers.
The issue I have is if I’m not physically near it, I can’t move it because there is no way for me to access the software controller during a work plan.
Request:
  1. It would be nice if a notification would pop up on my phone whenever it has any errors, like a gps signal loss.
  2. It would also be nice if I could access the software controller during a work plan so I can move it remotely. And I can then resume the plan.
  3. Icing on the cake would be able to see the cameras so I can see where I am moving it to.
Thanks!!!
Pause the plan and then you can control it and access smart vision. You might have to back out to the main screen and go back in to access settings. Move the rover and then hit resume. You can reboot sometimes too in order to recover gps. Just hit resume after it boots up.
Thanks for the tip. This helped out immensely.
Glad it helped!
