Would be great to have a double wide pattern for Lawn Mower
Thanks for sharing your suggestion.
If more users express interest in this feature, I’d be happy to pass the feedback along to our product team for consideration. We always appreciate ideas and suggestions that can help improve the Yarbo experience.
Curious what is meant by double wide pattern, are you referring same direction passes side by side? That would be a nice trick for getting to more of a u-turn effect versus the current which seems to be a cross between smart and zero, where it does mostly smart turn the suddenly zero as last adjustment.
Yeah zero turns need to be removed from the equation if smart turn is set.
Yep and still missing patches of grass that are clear pathing errors.
Could make this a parameter for the upcoming Zamboni pattern!
Vote for this one. Wider lawn stripe option
so it can do wider lawn stripes
This is a bit of my suggestion for tow mode. Yesterday I watch Yarbo make a full sweeping U turn on its own. I certainly like the idea of cutting like this too. Even though you would re-cut the ends it would likely be much faster.
You could increase the size of the stripe by increasing the turn radius or number of 1 direction paths. For example with Yarbo maybe 3 would get close to a 36 inch stripe with 4in over lap…this would also likely be a good no zero turn sweep allowing for continuous “forward” momentum and no back and forth jockeying.
