yarbojs-crypto started this conversation in Show and tell
yarbojs-crypto40 minutes ago
I am running a commercial Yarbo service operation in Switzerland, currently monitoring 5 Yarbo Lawn Mower Pro robots across multiple customer sites. I use Home Assistant as my central monitoring platform and have built a custom WhatsApp alert system (via CallMeBot) on top of your integration to notify myself and service agencies when robots encounter problems.
My setup:
- Home Assistant (latest stable)
- Your HACS integration (community_yarbo, latest version / v0.1.0 MVP)
- 5 × Yarbo Lawn Mower Pro robots across different locations
- Custom automations triggering WhatsApp notifications
Issue 1: Several error codes are NOT transmitted to Home Assistant
Description
Over the past two days I have observed at least two error types that appear in the Yarbo app but are never reflected in Home Assistant sensors:
| Error Code | Description (from Yarbo app) | binary_sensor._problem |
sensor._error_code |
CM003 |
Right camera blocked | stayed off / OK |
stayed 0 |
L001 |
Linear actuator problem | stayed off / OK |
stayed 0 |
Evidence: I checked the HA History for both binary_sensor.25070102b2dgd357_problem and sensor.25070102b2dgd357_error_code during the exact time windows when the errors were active in the Yarbo app. Both sensors remained unchanged at off / 0 throughout.
Questions
- Are
CM003(camera blocked) andL001(linear actuator) transmitted in theDeviceMSGMQTT payload at all? Or does Yarbo use a different MQTT topic for these error types? - Is there a known list of error codes that ARE reliably transmitted vs. those that are NOT?
- Is there a way to subscribe to additional MQTT topics (e.g.
plan_feedbackordata_feedback) to catch these errors?
Issue 2: sensor.{sn}_activity only shows standby / working
Description
The sensor.{sn}_activity entity in my installation only has two possible states: standby and working.
I noticed in your v0.1.0 Roadmap that the activity sensor is part of the “Core entities”. However, the error state (which would be a great fallback trigger for errors that don’t update error_code) never appears, even when the robot has an active error in the Yarbo app.
Questions
- Is the
errorstate not yet implemented in the current v0.1.0 MVP version, or is this a firmware issue? - When the robot has an active error (e.g. L001), does the
activitysensor transition toerrorin your test environment?
Issue 3: Using community_yarbo_error Event to read error codes
Description
I saw in your Roadmap that v0.1.0 includes the community_yarbo_error event, but does not yet include a dedicated error_code sensor entity.
Currently, when I trigger my automation on binary_sensor._problem, the undocumented sensor._error_code often reads as 0 instead of the actual error code (like RW001).
I am rewriting my automations to trigger on the community_yarbo_error event instead.
Question
- Does the
community_yarbo_errorevent payload contain the actual error code (e.g.RW001)? If so, what is the exact JSON structure/key to extract it (e.g.trigger.event.data.error_codeortrigger.event.data.code)?
Summary
My WhatsApp alert system works well for errors that correctly update error_code (tested with RW001 simulation). However, real-world errors like CM003 and L001 are completely invisible to Home Assistant, which defeats the purpose of the monitoring system for a commercial operation.
Any guidance on which error codes are reliably transmitted and how to best extract the error code from the community_yarbo_error event would be greatly appreciated. I am happy to provide MQTT packet captures or diagnostics if that helps.
Robot serial: 25070102B2DGD357 (Yarbo Lawn Mower Pro, firmware current as of July 2026)
Thank you for building and maintaining this integration — it is genuinely useful for professional Yarbo deployments.
Posted by a commercial Yarbo operator in Switzerland — 5 robots, multi-site deployment
GitHub Issue _ Briefing for markus-lassfolk_home-assistant-yarbo.pdf
Jörg Schüpbach yarbo.js@gmail.com Switzerland West +41 79 208 13 14
