How to align all work area cutting directions
How can I have all of my work area cutting lines aligned? I’ve tried playing with the offset but it seems like the initial direction in each area is random.
These pictures show an example of them being cut at different angles.
Turn off the rotation and adjust the angle so that both areas match what you want it to be. Or, set them to rotate the same number of degrees each time and play with the numbers to get the same angles visually.
Gotcha, I was hoping I was doing something wrong.
I’ll submit a suggestion to improve this.
