I know the wrenches have numbers on them, but is that the same if I wanted to go buy driver bits for the same sizes? I know i can’t go “full drill” mode when using them, but it would be nice to have a set of bits that can do all the wrench sizes
I don’t know the sizes off hand but they are standard metric bits as far as I am aware.
Hi there, the Allen key sizes used for Yarbo are M3, M4, M5, and M6.
These should correspond to the same driver bit sizes if you’d like to get a matching set.
Pro tip: Be VERY careful using driver bits on these screws. They are easy to strip. With a regular handheld battery operated drill, set the torque to 1 or 2 max. If more torque is needed, do it by hand. Because if certain screws strip, it can be very difficult to recover. Ask me how I know ![]()
After confirming with the team:
- Allen key 1 :M3(2.5mm)
- Allen key 2 :M4(3mm)
- Allen key 3 :M5(4mm)
- Allen key 4 :M6(5mm)
- Track Ratchet :M10(17mm)
The M3 is is the one that’ll get you. Because the fastener is a socket head cap, the drive is 2.5mm. This won’t end well if you use a 2mm ![]()
