Map processing times
Has anyone noticed that the processing time for a map take longer?
I used to be able to select all areas for mowing and it would comeback with a work plan in a reasonable amount of time.
Now those wait ti.es have gotten to the point where the second please wait for extra processing time pops up a lot more frequently.
Same here. Even calculating the way back to recharge takes much longer. But it always starts, just takes much longer and it always says “because of a complicated map processing time…” although the map is not more complicated than before.
Yes I’ve noticed a longer delay but haven’t gotten the second pop up yet.
Also have seen increased time, also have not got second pop up. Also seems to take more time when plotting path back to charger after completion. Result of the modification to varying paths? The extra time has not caused me issue, but thought I would reply in confirmation;)
I’ve also had it just give up completely due to processing taking too long, says something like the area is too complex I canny do it Cap’in!
But I hav not had it not be able to do anything at all.
I have had the core just decide to hang a 90⁰ turn right off the charging pad and drive out the side of my Yarbo hut too! But I think that more to do with the driving through NGZs issue that has cropped up recently.
Well hopefully that is fixed for you in the most recent 2 updates.
Hi there, thanks for sharing the feedback with us. Please keep us updated on whether this issue still exists after you receive the latest update. If it does, I’ll help share the feedback with our team for further investigation.
