It seems like there is a lot of space between the rover and mower/blower. And the charging pad spot that works for my property is near the edge of the woods where I’ve seen chipmunks, squirrels, rabbits, moles/voles, and I’m guessing mice.
What do folks do to keep critters out of the insides. I’m worried about them nesting and chewing wires.
I think with the frequency this thing should be mowing, I can’t imagine it will be an issue. But if your concerned you could put some blood meal around the charging pad periodically or some other type of mouse deterrent.
You’d be surprised how open that unit is. You could always place a few bait stations around it so they have a better food source that will actually kill them. The snow blower does exercise the module when it gets below freezing out. Not much, but it is something.
After first losing a lawn tractor in my shed to a mouse nest inside the engine cowl and over $2k in squirrel damage to a car left on my driveway, I cannot afford to just hope. I cannot say it works or not, but this is the first attempt at keeping those bastards away from Yarbo.
Same problem. We live in the boonies on Whidbey Island, so there are always rodents in the fields. With birds of prey overhead all day long, poisons are not an option, so I need a deterrent in the spring and fall. Winter Yarbo is inside the garage, where traps are set. Can’t really set traps outside though, or we will be catching some rabbits!
Best of all would be to put the boards inside some FRP housings, something the critters will not be inclined to chew .
Tim
I’ve had the same worry with equipment sitting near wooded areas, and what helped me was closing up any easy entry points with mesh, keeping the grass trimmed around the charging spot, and using light deterrents like peppermint oil or granular repellents so mice and chipmunks don’t feel comfortable settling in. I also put my station on a small raised platform to make the underside harder to reach, and doing a quick check every week or so has kept anything from nesting or chewing wires before it becomes a real problem.
That’s a valid concern, especially with the charging pad near wooded areas. Most people focus on prevention rather than trying to trap animals inside the unit. A few practical steps that work well are placing the base on a solid surface like concrete or pavers to reduce access from underneath, keeping the area around it trimmed and free of brush, and sealing any obvious gaps with hardware cloth or fine metal mesh that still allows airflow but blocks small animals. Some owners also place a galvanized mesh skirt slightly below ground around the pad area to stop burrowing. Avoid food sources nearby, and periodically check for nesting material or chew marks. These simple barriers usually discourage critters without harming them or affecting the equipment.
So, I believe that I’ve now experienced what is being discussed above. While my mower was with support, which can take time, is sat idle with Lawn Mower Pro attached. Additional errors occurred, and it was decided that a replacement wire should be sent to troubleshoot an emergency stop issue. Having opened up the unit to follow the wire change instructions, I believe that mower was home to a voracious rodent. This, like the user above points out, is ostensibly a function the huge gap and entry point to the mower, and makes a nice warm home for a rodent above the covered pcba board. If you plan to keep the unit exposed to the outdoors, then rodent entry is a very real risk. Need a ‘Smart-Yarbo Shed’ that opens and closes automatically, or a better way to protect the wiring. Wiring should, imho, sit in rodent proof loom, not be open. All fyi.
I’d reach out to support if you haven’t. I’m sure they’d help resolve this. Also, if your core didn’t have the protector, they can arrange to send you one.
