Mow along no go zone number of perimeters
When the mow along no go zone is selected it should either match the number of perimeter passes for the area or allow us to select how many passes to do, similar to perimeter configuration.
Thank you for your suggestion! We have passed your idea along to our product department for consideration. We appreciate your input and will keep it in mind for future updates!
Our product team is currently reviewing this feature request and would like to understand in which scenarios you would need this functionality. Could you please provide us with some examples or use cases? We appreciate your input!
IIRC from YT Crazypostman vids, Mammotion has this option.
The use case is selecting no NGZ cutting or no perimeter lap cuts does not expand the zig zag out to the entire area and get close to the borders. Also, it only seems to do one pass around NGZ’s now and doesn’t ride the border like it used to. The idea is to cut as much lawn as possible and minimize the trimming and manual touch ups.
Additionally, some people don’t like the lines around the NGZ objects so zero here as an option and the option the expand the zig zag close to the NGZ would be ideal for those individuals.
My scenario is that the mower doing the turns close to the no go zone is causing it to get stuck where it can mow along the perimeter fine without having issues.
Other situations are where the no go zone has more delicate grass where you want the mower to go over it the fewest number of times as possible. Mowing alone the no go zone for a few passes is much more delicate than turning around on it on each and every pass.
The more control we can have over the permiter areas to dial in the mowing the better.
Thank you for sharing your experiences! We’ve passed them along to the product team.
