Perimeter of the zones?
Why can’t my snowblower clear the perimeter of the zones?
It leaves a default safety buffer to account for track slippage and GPS deviations. You can create a sidewalk and add it to the work plan to clean up those areas.
I thought I had seen in the Wiki an option to blow or not blow the perimeter.
Nothing that I am aware of. It will do the perimeter first by default and it will throw into the area for the perimeter run, then clear the area. I recall seeing that recently. Is that maybe what you were thinking of?
Yes for the Blower.
Hi there, as @Kolbe mentioned, the “perimeter blowing” setting is available for the blower, not the snow blower. And as @bryan.wheeler pointed out, the Yarbo snow blower currently clears the perimeter of the work area first by default (except when using the slope pattern), and then continues with the internal routes.
Hope this helps clarify it! Let us know if you have any other questions.
Thanks, I was in slope pattern.
