Hello, I could use a little help with the physical controller. Everything else is working pretty well currently except the physical controller shuts off about 3-5 seconds after I turn it on. I hit the power button and the lights come on but then it shuts right off after a few seconds. I’ve tried holding the connect button right after I power it up but it still shuts off. About the only thing that works (sometimes) is if I press a bunch of buttons at the same time and then it will vibrate and stay on. Other than that, I’m fighting it to get it to stay on. Once it’s on I can connect to the rover and control it so I know it’s paired. Any ideas? Thanks
Have you held down the switch button to gain authority? That should force it to connect and stay on.
Hi there, could you pelase check this article to see if there is any steps missed: [2024] Yarbo Physical Controller Instructions | Yarbo Wiki Feel free to let us know the results after you follow the steps provided in it
I’ve tried that a few dozen times right after turning on the controller and it doesn’t work. The only thing that works is a random push of a lot of the buttons and then it sometimes stays on. After it’s on, I can connect via the switch button and it will control the rover but after I power off the controller I have to repeat the process all over again. The controller works the rover but it’s a pain to get it to stay on.
Thanks, I will try that again this evening and see what happens.
I had similar experience with the physical controller where I got frustrated with it and went back to use the phone. I will try again based on the suggestion
