Recharge at 10%
The current minimum recharge triggers at 15%. Does anyone find that it takes more than 2-3% to get back to the dock? I’d really like that extra 5% available. I’ve seen multiple times it could’ve completed an area if it were.
I, and maybe others that I’m not aware of, have recommended this to Yarbo and was told it’s been talked about internally but not a priority at this time.
I don’t but I am not mowing 6 acres either.
I’m doing 4+. I guess if if was 10 ft wide and 17,424 feet long it could be a problem. That’s what ChatGPT said anyway :slight_smile:
I get it. Several other things I’d like to see first.
Hi there, I understand your need for this and will continue to follow up on others’ interest in this feature to evaluate its priority. Thank you for sharing your feedback!
Depends on which module you are using. The lawn mower makes it back easily. The snowblower shuts off the auger at 5%. My driveway is 700 feet long. When clearing the end farthest from the docking station in a heavy storm I found that I needed to set recharge at 22% to make it back.
I thought might be the case for the winter users. Still, letting the slider drop another 5% wouldn’t hurt for those who want it.
