Has anyone suggested an option to set the height of S1 module at launch? The default height is too low and it bangs unnecessarily coming off the dock. I just need another .5 inch or so.
All my areas, pathways, and sidewalks are set to 2.01in & dock clear 0. My concern is launch-Before I launch it I will manually take control and raise the module to 2.01 height. Go back to the app and stat a plan. it will correct my module position lower the height below 2.01, launch, bang the sidewalk, then raise the module to the plan height.
Can we have a launch height setting?
Thanks for your suggestion and for explaining the scenario where you need this feature. I’ll pass your idea along to our product team for consideration. If you have any other feedback, feel free to share!
Yes, I have suggested this many times. Yarbo says it’s necessary to remove gathered snow in front of the dock. And I said “Great, but what if there’s only ice, or gravel in front of the dock? Yarbo is pushing futilely, unable to undock, because it insists on the lowest possible auger setting!”
But that was last snow season, and nothing has changed, no undock setings added. So it mostly works now, when the area in front of the dock is perfectly manicured. But I know very well, as the season goes on, and ice develops and gravel pushed, I will have to manually undock and begin every single work plan, because the ability to simply raise the auger when undocking isn’t there.
Hmmm, I thought it was going to the height of the path exiting the dock…
I wish. It won’t reach that height for several feet beyond the dock.
Yikes confirmed…![]()
It lowers then launches, stops and then raises back up to the 2.01” path height
Is that what they mean by plow mode?
cross link: Dock clearing height setting
Any progress on this issue? Seriously- it couldn’t be that difficult to resolve,
Nothing I’m aware of
They did change the behavior somewhat. If it doesn’t make progress in the lowest position, it is supposed to raise up and try again. Not sure this will work in all cases, maybe only for ice. But at least it’s something.
