I was given quite the deal to get the pro module. I am starting to wonder if it’s worth spending the extra money to get one. I have 1.7 acres and I get tied of the plastic cutting disc breaking over every little thing. Usually a cutting disc last about one to three cuts of my lawn.
Just looking for feed back if I should spend over $1,500 to get the pro while I have this special offer.
Yes - I love the pro mower and the freedom it gave me not having to agonize over a branch or anything random breaking the disks. It’s a beast of a mower deck. Can cut thick, tall, wet grass with ease.
Yes, the Pro Mower is an upgrade, but you’ll need to remove the plastic blade and replace it with the straight blade. The Pro Mower includes a straight blade. The Pro Mower has ultrasonic sensors that let it detect objects. I also upgraded my antennas to the Pro antennas for better operation under trees and other overhead obstructions.
@kenjii6441 are you asking Y40P vs Y40 Core -or- standard Mower vs Mower Pro?
If you’re asking specific to the Mower absolutely get the Mower Pro. #1 they have discontinued the standard model. It rarely makes sense to buy a discontinued product especially given the physical nature of the mower (ie you will may need repairs at some point in its life). #2 the Pro Mower can be equipped with traditional blades or razors blades based on your need.
If you’re asking about the Core that is a more nuanced question. If you have a mostly traditional suburban lawn, than the Y40 is a good choice. Use the savings and buy another module. If your property is more rugged/rustic/hilly than the Y40P is a better choice.
I second equipping your Core and Data Center with Pro Antennas. Do it now and you won’t regret it. It sucks having to get on your roof to change the Data Center antenna later.
