Good day,
I have a temporary hole in the ground and created a no-Go-Zone around it.
On the Screenshoot it is the big one on the left side under the long red No-Go-Zone.
However, the No-Go-Zone goes over the area boundary and now I cannot more mow.
But it was 2 month in another place working.
What to do?
Note: It took me 2 whole days to create an 640m2 area because of GPS/Network failures.
Hi there, when you say you “can’t mow anymore,” do you mean Yarbo is unable to calculate the route for the Work Plan?
Could you please share the exact error message you’re seeing in the app? That will help us better understand what’s happening and look into it further.
The section in yellow it likely where you’re problem will be. Parts of it are precariously close to being cut-off from the rest of the map which will cause a mapping error. I would drop a Rectangle template NGZ over that area so it doesn’t try to get there.
Make that part in yellow all a NGZ. Abandon that section or manually cut it.
A little late to the party but it might just be this blue section too
