The Y40P is here!
Here are some photos of my Y40, purchased mid 2025, and the new Y40P. One thing I didn’t realize was the Y40P only comes with high-rise antenna mounts. It no longer comes with the low-rise bases as an option…unless that was missing in my shipment.
Those are the flexible mounts standard on the Y40 also
I have those for the Y40 too, the original solid high-rise mounts, and I also have the standard low-rise mount which I prefer.
I like the low mounts also.
I love the flex mounts. They move out of the way if they come into contact with something. The low and old mounts won’t budge and break the antennas and antenna connections. Far less likely to have an issue with the flex mounts.
I get that, I just don’t have anything low-hanging where it would be needed. I did put the high mount on last winter for snow clearance but moved back to the low mount for mowing.
I did the same, tall in the winter, and short in the summer. Part of the reason is I put a sandbag on top the core in the winter for more weight.
Thanks for sharing the photos! Regarding the antenna mounts, the flexible mounts are the standard configuration for the Y40P, and low-rise mounts are not included.
