I bouht the Yarbo this on October 2025 and i was told.to choose the core version 2024 in application, but i got the regular tow hitch in box although according to the wiki Understanding Yarbo Tow Hitch & Towing Capacity | Yarbo Wiki I should have the upgraded bracket tow hitch. Do i really have 2023 version? How can i tell that?
Another observation about tow hitch is that the screw is too short and it barely can be tightened and it loosens after short time. To address this, i’m just using another, a bit longer screw.
The original screw here in picture.
That’s the 24 version. Here’s the 23.
I also think the screw is slightly too short. Mine also used to come loose quite quickly.
Now I’m using a longer screw, and a lock washer.
Hi Andris, thanks for reaching out! The tow hitch that comes with your Core is the 2024 tow hitch. The upgraded Tow Hitch + BBM you see on the Wiki is different from the standard tow hitch included with the machine.
Ok, now I see the Wiki article is modified.
Do I understand correct that I can’t install Tow Hitch + Back Brace Mount to my 2024 Core if the back Brace mount was not included in the box, right?
Correct. The back brace mount is new and has its own hitch.
