Trimmer issues
my trimmer wont turn on in the areas that i have set on the map. I’m not a big tech guy so I’m sure its something simple, just wondering if anyone has suggestions?
Do you have trimmer enabled in work preferences and in the area settings?
Thanks for reaching out—we’re happy to help!
Could you please share a bit more detail about your map and the work plan you’re using? This will help us better understand what might be causing the issue. In particular, please make sure that:
  • The area you want to trim is included in your work plan
  • The memory path (if you’re using one) is also added to your work plan
If you’re able to share screenshots or a short recording, that would be very helpful for us to take a closer look.
