Yes several users have them. I have a preproduction and also have the production model. I still have the preproduction installed. I think the path planning still needs some work, especially for tight spaces. However, you can use memory path to record a path for these areas. Trim edge (like drawing a snow throw line) along the boundary works very well on straight lines and smooth arcing turns. Here are some links from the wiki. Let me know if you have any more questions.
Thank you sir. I have a lot of aluminum picket fence around my pool that consumes trimmer line with my handheld trimmer. Have you seen or heard how it works on something like this?
It works really well. The wheel will run along the fence and the spring loaded swing arm will push back and ride against it. The wheel really helps keep the string use to a minimum. Makes it very efficient. Backing in tight corners can be a little tricky though. Again, use memory path for those areas.
Thanks for the link. The App side actually looks pretty intuitive and well thought out.
So much for saving a summer map and a winter map. ![]()
Can still save up to 10 locally on the core. Cloud is just the one.
