Unexpected trimmer behavior
A day or so ago I decided to attach the trimmer attachment to my new(ish) core to handle some out of control weeds.
The line broke frequently, which caused a line feed error; this was not unexpected as this is what has always happened when I send it to battle my more sturdy weeds.
But, what was unexpected, when I sent it back to recharge (there is a more comfortable spot there for me to lay on the ground to refeed the line), each time it passed an edge of an area on the route back it tried to trim it! This of course resulted in a line feed error message and aborted the journey back to my charger. After several times of this happening I just shut it down, removed the trimmer. Powered it back up and sent it merrily on its way back to the charging dock.
This is currently not something that is preventing me from making progress, and it hasn’t happened multiple times yet, so I haven’t bothered creating a ticket.
I am sharing here as a curious quirk and to see if others have seen something similar.
I think I’ve seen this too when it gets close to a trim edge. You can disable the trimmer in the area settings and also globally within work preferences. That’s the quickest way to turn it off and send it on its way. It will say (trimmer off) on the main screen.
Perfect! Thank you.
Hi there! Aside from the workaround Bryan shared, if you continue to see this behavior, please feel free to submit a support ticket so our team can take a closer look at what’s happening.
