Unified Perimeter
When running a work plan with areas that touch/overlap, it would be great to have an option to for the perimeter to only loop around the combined Area. This could save a lot of mowing time by eliminating perimeters of individual areas inside of the combined Area of the work plan.
In my map below, eliminating the slow crawl in the highlighted sections could shave off an hour of mowing time (estimated).
Yes being able to combine multiple areas into one for a scheduled work plan and path planning is a great idea. Would be much more efficient and help keep a consistent appearance.
Thank you for sharing your suggestion. We understand the potential time savings from having the perimeter follow the outline of the combined area, rather than each individual section.
We’ve passed your feedback along to our product team for consideration. However, based on our initial assessment, this may not be something we’re able to prioritize in the short term. We truly appreciate your input and will keep it in mind as we continue improving our system.
