Universal Crawl Mode
I notice with the mower that there is a high and low travel speed, but I dont see that with the snow blower. I’ve also had a problem with accidently starting the blades on the snow blower while navigating with the phone app. If your finger moves just a bit too far the the left, it will trigger the impeller, which could actually be a bit dangerous. I’ve also had difficulty in delicate situations with sudden higher velocity movements like when navigating close by my car, and while trying to drive the core onto a work table. My suggestion would be a couple universal buttons that would a) limit speed to very slow and b) disable all modules from running.
Agreed, the controls for the mower have the same issue with the cutting height getting hit and adjusted accidentally as well. That control (and others like it) needs to be locked with a tap and hold to unlock or something. You can toggle speed with the physical controller in the interim. Would be nice if you could for modules other than the mower too.
Thanks for your suggestions! Regarding your concern about the impeller control layout, I’ve shared this feedback with our app team for further review.
As for your other idea about adding a universal low-speed mode or global module disable button, we may not consider changes in that direction at the moment, but we really appreciate you bringing it up. Feedback like this helps us improve, so please feel free to continue sharing your thoughts!
