I’m seeing a lot more missed routes in this version. This example is an unchanged area set to Checkboard. I’m seeing this in several Areas where it didn’t happen before.
That’s a new design. X pattern
Not a fan of this new pattern ![]()
Oh wow. That’s surprising.
X marks the spot. Perhaps it’s just telling you where the buried treasure is!
Are you still using checkerboard? Saw a FB post earlier that someone had a weird pathing issue and it was the path offset that was causing it. They tweaked that and it fixed it. Checkerboard doesn’t support that, but just a thought.
I’ve seen something like that last week.
But yesterday i done last update and don’t see this anymore.
I wasn’t using checkboard (i used parallel) and i see big gap at the middle. i don’t think to cpture the plan.
Yep. Checkboard. Keeping a closer eye on it.
At the moment, we’re not certain whether this is related to the recent update. It would really help if you could submit a support ticket for this issue, so our team can review the logs and investigate further.
I didn’t note a timestamp for this one. I’ll open a ticket with better details when I see it again.
