Weighted side plates
Was thinking of getting the weighted side plates to improve snowblower down my slope driveway. When my yarbo stops while going downhill, it will top forward raising the back end off the ground. Had anyone tried these plates and if so how will do they work?
Try this link - Side plates
They are brand new, not sure anyone has had an opportunity to try them on the snow blower yet.
The weighted side plates add approximately 4.3 kg (9.5 lbs) per side. They can help improve traction and overall performance on slopes by adding additional weight and stability to the unit.
While results may vary depending on the slope and surface conditions, they may help reduce some of the issues you’re experiencing when operating on a downhill driveway.
When will it be possible to buy them in the EU?
I have the driveway in one part with a serious slope. I played around with different weights and found that minimum in my case was extra 20kg. I have bought some gym equipment weights from Dechatlon sports shop here in EU. Was reasonably priced and it did made the snowblower the autonomous helper as it’s advertised. Without the extra weight it did cot stuck all the time because of the low clearance and because of the slope I have. Adding something that large to the back of the robot, then you also need to make new snow blowing maps again that the robot would have more room to maneuver without hitting things.
Before the added extra weight it was daily work for me to help it to get unstuck. I can now remember only one time this last winter I had to do this.
There is a post I wrote about this upgrade and you can see the picture here:
I’ma leave this here…:sweat_smile: Weighted Side Plates received
