Work Preference settings going back after saving.
The Work Preference is defaulting back after about 20 minutes. Trying to keep the auto light mode off so i can run at night without using vision but after about 20 minutes the lights turn back on and the setting in work preferences is restored (auto light mode turned back on). I have made sure to save the setting and turn the lights off and ill watch it on the camera for a while, itll keep lights off then the setting just turns back on. Also recharge turning mode changed back to smart turn after i had it on zero turn.
Hi there, if this happens again, please submit a support ticket and include the approximate timestamp of when the issue occurs. This will help our support team investigate further and identify the root cause more efficiently. Thank you for reporting this.
Can you even run any module at night with the lights off? I thought you could only turn then them off durning the day.
Admittedly I have not tried, but I don’t think so.
If you turn off Auto Light Mode and manually keep the lights off, they will not turn on automatically at night.
Please note, however, that running Yarbo in the dark without lights may affect its visual system and overall performance.
What if you have obstacle avoidance set for moderate bypass or the bumper is activated in gentle contact mode? Would the lights be forced on? I also assume that the amber strobe would still remain on.
