Since the recent update I see that all the lights are on when my Mental Mower goes out on a plan. (It’s 3PM CST, and not a cloud in the sky.) I’ve paused the plan and manually shut them off, but when I resume they come back on. I’ve shut down and restarted the system and nothing changed. Is anyone else experiencing this? I’m gonna try a hard reboot next and see what happens.
Do you have auto light enabled or disabled? They are LED lights, so it won’t hurt anything with them being on. Actually does help a little if it goes into shadowed areas.
Hi there, if Auto Light Mode is enabled, Yarbo will automatically control the lights based on the surrounding lighting conditions. Even if you pause the Work Plan and manually turn the lights off, they may turn back on after you resume if Yarbo detects that the environment is dim.
However, if the surroundings are clearly bright and the lights still remain on, please first check whether there is any dirt or debris blocking the camera.
If the camera is clean and the issue continues, please submit a support ticket with the relevant details, including the troubleshooting steps you’ve already tried, so our support team can look into it further.
Update. Hard reboot took care of the issue. I always have Auto Light feature turned off as I only schedule daytime work hours. That’s why I was concerned. I’ve been noticing that every time an update comes out, there is a small glitch (Usually lights) involved in the first time I run a workplan. I’ve also noted that my hard reboots after the updates corrects these issues. So moving forward, I will always do a hard reboot before I run my first workplan after an update to ensure that everything is in check.
Yes a full shutdown and power up after is always advised. And if you encounter any weird issues.
