Yarbo only charging to 90 some percent
Noticed the last couple days my yarbo will not charge to 100% right now it is at 92% and appears to be done. Is that a cold weather feature?
Does it say that it’s charging, but just never fully charge?
Yeah it’s in the charging mode but never goes above 92%
@marriott001 I had the same issue, and they are replacing the battery. Here is what they said will reset the battery and it usually works, so by usually I will assume that is Yarbo speak for almost never, but here goes.
  1. Use the cord they sent with it and plug it in for 2 hours.
  2. Turn it off / pull the plug to the battery and let it sit for 4 hours.
  3. A Miracle apparently happens
  4. Turn it back on and see what happens - hopefully its all better now, if you have my core continue to 5.
  5. Open a ticket for a replacement battery
  6. Wait a week and have a lot of calls, emails and frustration
  7. You finally get approved for a new battery
  8. Wait, wait wait.
  9. A Christmas Mircle
  10. FedEx Tracking is received
Give 1-4 a try…hopefully you have better luck than I did.
Hi there! I’ve seen your support ticket in our system. You can first try unplugging the battery and letting it sit for about 4 hours to see if that helps resolve the issue. Please keep us updated on the result through your support ticket. If this doesn’t help, we’ll move on to the next step.
As I put on the other thread. What is your temperature. When really cold mine cycled between 90 and 94 with the warming message regularly.
My unit is going through this again.
This time I notice it was only charging to 98% then after a few days of use will now on charge up to 78%.
I did kick Yarbo off of the charging pad and had it redock.
It did charge to 79% but then dropped back to 78%
I haven’t dont the un plug for x hours thing yet because my Yarbos are 60 miles away!
Has Yarbo figured out why some units do this?
Try kicking it off the dock for 4 hours and see if that helps. Shutting down also works if you have someone who can turn it back on. You can also submit a support ticket and they can check the battery out. It’s possible it’s got an issue.
Hi there, thanks for sharing the details.
As Bryan suggested, please try unplugging the battery for about 4 hours to reset the BMS. If the issue persists after that, we recommend submitting a support ticket and including the troubleshooting steps you’ve already taken. This will help our team investigate further and assist you more efficiently.
