Yarbo’s ‘Amazing’ Route Planning… So Efficient It Hurts!
@zeusmos - Yarbo said it was a “defective BMS inside the battery”. I am sure it is like most new batteries, and it is smart / BMS = Battery Management System I think.
In short this is what mine was doing and I noticed it from day one but just assumed this is how it worked. Would charge and around the high 60’s to 70’s percent it would hang then jump to 100%. I called after it was in the middle of a scheduled job this week and went back to recharge, it sat on the charger for 10 hours and was at 75 percent I think, would fell back to 73 then to 75, kept that ping pong up for several more hours until I called Yarbo. After doing the plug in for 2 hours to cord / house power then shutdown for 4 to “reset” the battery it was back to stalling in the 60’s then jump to 100.
Yarbo said this was the issue (defective BMS), but I still need more approval to get the replacement battery. I love the bureaucracy - makes the entire customer service experience even more enjoyable.
Now I wonder if this has been the root of most of your issues. A bad battery makes a lot of sense if the voltages or amps are inconsistent.
@mike1 Great addition! I’ve shared this with our product team for consideration.
@bryan.wheeler I hope so!
Good to know. I didn’t thought Yarbo battery had a BMS inside.
This is my first time using the unit and I have the same issue. The route pattern selected is inefficient. The unit throws snow in areas already cleared. The unit moves before the chute is finished turning. Neither the parallel nor the circle patterns work in my situation.
What do your snow throw directions look like? Got a picture of your map you can post? Preview mode if possible.
Hi there! Thanks for sharing your experience. To help us better understand what’s happening and offer more tailored advice, could you please share a screenshot of your map? That way, we can take a closer look and suggest ways to improve how it works for your setup.
This view of the RTK Details is for the Data Center itself.
