Yarbo Weekly News Issue 50- December 3rd, 2025
Get to Know the Yarbo Plow Blade
The Yarbo Plow Blade makes it easier to handle wet and packed snow. To get the best performance, be sure to explore the Plow Mode settings and customize them for your needs.
Once the plow blade is installed, open Yarbo Settings and enable Plow Mode. From there, you can set the snow-plowing direction and configure the plow blade settings for each working area.
(Plow Blade Installation Guide: https://www.youtube.com/watch?v=nmVFDd_W8tI))
You can fine-tune the plow blade by adjusting the Overlap and Auger Minimum Height. If you choose to run the job twice, you can set different parameters for the second pass. You can also enable Cleanup Trace on the second round to automatically shift the route slightly and ensure a cleaner finish.
FAQ: Why is the snow-throwing direction different from my settings when Yarbo is clearing the perimeter?
Yarbo will always clean the perimeter of an area before starting the internal routes. While clearing the perimeter, it will first attempt to throw snow in the direction you selected. However, if the chosen direction is not reachable during a perimeter pass, Yarbo may temporarily throw snow toward the inside of the area. It will then clean that snow during the following passes.
What’s the estimated release on fixing some/most of the chute direction issues? The perimeters aren’t even going the right directions. This one starts out correct but once it makes the first corner it’s aiming the wrong way and then switches to blowing snowing onto the siding of the garage, also still not to the center. :melting_face::melting_face:
They’ve been “looking into it" since last winter.
In fairness to them. Fire of the day (Both literally and figuratively) took precedence. Let’s hope it get resolved ASAP. Tis the season.
I’m looking forward to a good bugfix and feature enhancing release soon!
Hopefully sooner rather than later.
Yarbo’s Christmas present to us and our families :heart::grin:
Yeah, kinda thought they would have cleared their S1 backlog fixes with a couple firmware updates nuggets for us to chew on by now and shut us up for a min :laughing:
Monthly historic cadence says it’ll be end of December. But with Christmas I’m guessing January.
Let’s hope for a Christmas miracle and we get a surprise firmware release next week! :slight_smile:
We’re currently exploring ways to optimize it, and we appreciate your patience.
So im guessing that asking about chute direction in relation to the wind is wishful thinking?
Definitely not on the todo list. I’ve seen them state as much a few times. However, the manual approach suggested I feel is something easily done and more likely to be implemented.
They need to make the auto scheduling reliable first. Wind can be mostly overcome by aiming the deflector down.
