Yet another NGZ Incursion - Propane Tank
Yep - that is consistent with its rules for the boundary that it can be half a cores length over. I think the reasoning is because when you map the mapped boundary line, it is split down the middle of the core. I have never agreed with this methodology. It has done this from day one. But, NGZ’s they did stop crossing that line sometime last year. It seems that behavior is removed. It never made sense for NGZ’s nor the perimeter either. It’s how the core gets itself into trouble with that big booty.
The only time it should ever drive over a boundary line (any boundary line, perimeter, NGZ, etc) is when it is cutting the boundary. And when it is cutting that boundary, it should follow the mapped path line EXACTLY as it was driven during mapping. Any other time, never cross the boundary line, ever. Very simple in my book.
I don’t know that wouldn’t have backed in further. It’s at the point where the tank trips the E-Stop.
If so, that would be an even bigger issue. Either way, this needs to be priority for being fixed.
I have a no go zone around a large maple tree and I just watched it run in to it and sit there spinning in the grass against it. I made the no go zone by driving around the tree.
It’s out of control at this point. Might as well call a NGZ an Area. It treats them all the same. It’s straight up math and someone’s bad at it. AI would find the errors in their juvenile code in about 90 seconds. A human can then verify and deploy. This runaround we’re getting about how hard it is to figure out is utter and total nonsense!
Well, turned OFF NGZ borders today. It didn’t go any better. Next they’ll suggest I map 12’ away from any Hazzard. I get it, there are things I could do to work around this, but I’m sick and tired to working around persistent issues that DON’T get fixed.
Last I checked “centimeter grade accuracy” did not require a 12’ safety buffer
It didn’t used to be bad like this. Something changed earlier this year, and they haven’t been able to fix it yet.
#startoveritaintworking
I hear you and no you shouldn’t. What you have done should be more than sufficient. Something is seriously wrong and they need to address it ASAP.
forgot this one from the same today.
Well maybe if you would put a fence around that propane tank you would not have that problem. Yarbo’s stay far away from fences. Wait maybe not, let me think on this. Redraw your map, that should fix it, or maybe just the paths to the area…
Maybe it will get fixed in the second upcoming update…
That is the line I got told recently.
… or I could remove the tank and forgo heating my pool - all very viable options :laughing:
Yeah put the tank on top a pole then it can’t hit no stupid button.
You rich people with your pool money got all these problems.
Sorry sir, you own how many Yarbos? Ha
First World Problems
@cobradunn @B-Mod I’m really sorry for the frustration and inconvenience this issue has caused. We’ve recently consolidated the feedback regarding NGZ intrusions and shared it with our Product and R&D teams. They’re actively working on addressing this issue, and we understand how important it is to ensure Yarbo respects the mapped boundaries.
