If your Yarbo controller loses connection or if you’re setting it up for the first time after some maintenance, it’s easy to reconnect the physical controller with your Yarbo core. Simply follow these steps:
Step-by-Step Guide:
Step 1: Power Off the Controller
- Press and hold the logo button on the handle for 5 seconds to turn it off completely.
Step 2: Restart the Controller
- Press and hold the logo button again for 5 seconds to restart the handle.
Step 3: Prepare Yarbo for Pairing
- Press and hold the power button on Yarbo for 3 to 5 seconds until the power indicator lights up. This puts Yarbo into pairing mode, ready to connect with the controller.
Step 4: Pair the Controller with Yarbo
- Once pairing begins, the Bluetooth indicator light on the controller will turn solid after a successful connection, indicating that Yarbo and the controller are now connected.
Tips for Reconnection
- Ensure both the controller handle and Yarbo have sufficient battery levels before attempting to reconnect.
- Keep the controller and Yarbo close to each other during the pairing process to avoid connection issues.
By following these steps, you can successfully reconnect your Yarbo with the controller for seamless operation.
