[2024] How to Utilize Schedule Feature
1.What is schedule?
The schedule feature within the app allows Yarbo to execute tasks automatically at specific times.By creating a schedule, Yarbo can operate seamlessly, executing tasks automatically without the need for manual intervention.
2.Where to Find it?
To access the schedule settings, start by selecting "Enter My Yard " on the map page. Once on the My Yard page , navigate to the menu below and click on "Schedule. " This will take you to the schedule settings, where you can create a work schedule for automated task execution.
3.how to schedule it?
Create a Schedule
  • If the current time has exceeded the start time that is set for the new schedule, the schedule will be excuted to the next day. For example, if the schedule is created at 9 a.m with a start time of 8 a.m. It will be executed on the following day.
  • If the current time has not exceeded the start time that was created newly, the schedule will be executed on the same day.
  • If the time difference between the current time and the newly created start time is less than 5 minutes, the newly created schedule will promptly enter the paused state.
  • Only one schedule is allowed within a specific timeframe. If a new schedule is created with overlapping time, it will overwrite the existing one.
Step 1: To initiate the scheduling process, navigate to the Map page and click on “Schedule” Within the My yard, locate the “Schedule” feature.
Step 2: On the Schedule page, click the “+” button in the top-right corner of the page to begin creating a schedule for a designated plan.
Step 3: Set the “Start Time,” “End Time,” and Your local time zone for the work schedule. This allows Yarbo to execute the plan accordingly.
Step 4: Next, select a plan from the plan list.
Step 5: Once satisfied with the schedule settings, save the plan to enable the Yarbo to automatically execute the work plan according to the defined schedule.
4.Execute a Schedule
  • When the battery level is below 20%, Yarbo will automatically return to its base to charge until the battery level is above 80%, at which point Yarbo will continue to perform tasks, all according to the schedule you set.
  • Yarbo will continue work when the battery level does not drop below 80% after a work plan on a schedule has been completed.
  1. When Yarbo does not execute schedules or plans
The plan you have scheduled will be automatically executed by Yarbo upon reaching your set start time.
  1. When Yarbo executes a schedule
  • The scheduled plan will begin to execute automatically as soon as its trigger time arrives if Yarbo is currently performing a non-scheduled plan.
  • When you manually cancel the current work plan, the schedule will only be automatically restarted at the next scheduled start time.
  • A schedule that is currently in progress can be viewed, but not edited or deleted.
  • The work plan in the schedule is still being executed when Yarbo reaches the end time, and it will return to recharge when the work plan is completed.
  1. When Yarbo executes another schedule
Yarbo will continue to run the current schedule even if another schedule is about to execute.
  1. When Yarbo running work with the app’s controller
The schedule will be prompted for automatic execution when time comes, and you can decide whether to run it.
5.Delete a Schedule
  1. Find the “Schedule” feature by going to the Map page and clicking on “Schedule.”
  2. Click “Schedule”.
  3. Select the target “Schedule” to delete.
  4. Click the “Delete Schedule
Ticket ID #82578: Unable to save Central Standard Time zone.
*June 2025: issue remains
*Photo Links
  • Scroll screenshot image notes for details
*May 2025: reported issue
I’m sorry for the inconvenience this issue has caused. I’ve reviewed your support ticket and would like to clarify the expected timeline for the fix.
This issue is scheduled to be addressed in the following update — not the one that is about to be released. We truly appreciate your patience and understanding as our team continues working to resolve it.
Thank you again for bringing this to our attention.
I have 3 schedules, snowfall notification on and Automatic on. However Yarbo started with notifying me of a schedule to be started soon, but started automatically without snow.
Was not intended. Intended was to let Yarbo start automatically when there would be snow without waiting for any interaction from me, but also it should not start without snow. What to set up that Yarbo really starts with snow?
It should start when the forecast has determined an inch has fallen as is my understanding. I’d suggest submitting a ticket with the time it started automatically so they can dig into why.
