[2024] What if the Docking Station Cannot be Placed in Steep Areas?
To maximize Yarbo’s performance and prevent potential damage, it’s essential to place the docking station on a stable, level surface—especially in areas with uneven terrain. If positioned on a slope, Yarbo may slide, leading to charging interruptions, reduced efficiency, and potential damage to the device.
To address this, we recommend creating a level platform for the docking station by leveling a section of the terrain and reinforcing it with a sturdy, weather-resistant board. Start by selecting a location with minimal slope, if possible, and use a shovel or leveling tool to excavate and flatten the area. Lay down the board to create a solid foundation that Yarbo can dock onto reliably. Ensuring the platform’s tilt is less than one degree is crucial, as even slight angles may impact docking alignment and charging stability.
A leveling tool or smartphone app can help confirm the platform’s angle before placing the docking station. Regularly check the level of the platform to account for any shifting caused by weather or natural ground settling. Taking these steps will ensure Yarbo docks and charges effectively, providing a safe and dependable docking area and minimizing risks for long-term use.
How much of a step up is manageable at the front of the docking station. The photo you’ve provided of the docking station on the grass looks quite high. I haven’t used the mower yet but I’m pretty sure that much of a step up may cause issues for the snow blower. What height can both the snowblower and mower tolerate? Personally, I want my docking station to be in a position where it can be used for blowing as well as for mowing.
mowing is more forgiving for lift or drop off but +/- 1 degree is the recommendation of slope and the docking station should be on a flat surface and be flush with it especially for the snow blower.
@Yarbo-Forum The title of this should be changed to “Can the docking station be placed in steep areas”
